http://banners.pgmfi.org/
[DataLogging] QD3 / ISR Info C#
http://banners.pgmfi.org/viewtopic.php?f=54&t=24512
Page 1 of 1
Author:  bmgjet [ Sat Feb 02, 2019 6:03 pm ]
Post subject:  [DataLogging] QD3 / ISR Info C#
Had a bit of a mission set out for myself to get QD3 logging directly to my dyno.
Bits of info were scattered every where so thought id make a post with it all in 1 place.
Here is what I came up with for processing QD3 serial string.
Use it how youd like.
 using System;
using System.Collections;
using System.Windows.Forms;
namespace QD3_processor
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            //String to test
            byte[] byteData =
                0X46, 0X26, 0Xc7, 0X05, 0X05, 0Xed, 0X00, 0X5d, 0X02, 0X74, 0X08, 0X48, 0X00, 0X80, 0Xb1, 0X22, 0X57, 0X0a, 0X49, 0X46, 0X00, 0X93, 0X23, 0X25, 0X22, 0X7c, 0X00, 0Xff, 0Xff, 0X00, 0X93, 0Xa9, 0Xa2, 0X72, 0Xbc, 0X02, 0XA8, 0XA0, 0X00, 0X00, 0X5D
               // 0X46, 0X26, 0X5f, 0X08, 0X02, 0Xed, 0X01, 0X80, 0X08, 0X74, 0X00, 0X65, 0X00, 0X80, 0Xf5, 0X25, 0X57, 0X0a, 0X49, 0X46, 0X00, 0X8f, 0X3f, 0X2b, 0X29, 0X7b, 0X00, 0Xff, 0Xff, 0X00, 0X8f, 0Xa9, 0Xa2, 0X75, 0Xfc, 0X02, 0X00, 0X00, 0X00, 0X00, 0X96
            //Calls decode of QD3 data stream.
            QD3Decode(byteData);
        private void QD3Decode(byte[] byteData)
            byte rpmLowRaw = byteData[2];           // Low Byte of RPM
            byte rpmHighRaw = byteData[3];          // High Byte of RPM
            byte ignRaw = byteData[9];              // Ignition Timing Raw
            byte o2Raw = byteData[11];              // Oxygen Sensor Byte
            byte vtecRaw = byteData[19];            // Vtec Engaged Yes/No
            byte vssRaw = byteData[20];             // Vehicle Speed Sensor Byte
            byte batteryRaw = byteData[21];         // Battery Byte
            float mapRaw = byteData[22];            // Map Sensor Byte
            byte tpsRaw = byteData[24];             // Throttle Position Sensor Byte
            byte iatRaw = byteData[25];             // Intake Air Temp Byte
            byte ectRaw = byteData[33];             // Engine Coolant Temp Byte
            byte injLowRaw= byteData[7];            // Injector low Byte
            byte injHighRaw= byteData[8];           // Injector high Byte
            byte knockraw = byteData[10];              // Knock sensor Byte
            byte cel1 = byteData[36];               // Cel Byte1
            byte cel2 = byteData[37];               // Cel Byte2
            byte cel3 = byteData[38];               // Cel Byte3
            byte cel4 = byteData[39];               // Cel Byte4
            //RPM
            float rpm = 1875000 / ((rpmHighRaw * 256) + rpmLowRaw);
            //Injectors
            double injms = ((((256.0 * injHighRaw ) + injLowRaw) - 24.0) / 4.0 ) / 57;
            double dutycycle = Math.Round(rpm * injms / 1200,0,MidpointRounding.AwayFromZero);
            //Knock retard
            double knock = (0.25 * knockraw);
            //Ignition Advance
            double ign = (0.25 * ignRaw) - 6;
            //O2 sensor voltage 0-5V
            double O2 = o2Raw / 51.0;
            //TPS %
            double TPS = (0.472637 * tpsRaw) - 11.46119;
            //Battery Voltage
            double battery = (26.0 * batteryRaw) / 275.0;
            //Map Voltage
            float mapvolt = mapRaw / 51;
            //Map Mbar
            float map = (1764 / 255) * (mapRaw) * 2 + 6;
            //Map inghg
            double inHg = -10.87 * ((mapRaw) * 5 / 256) + 30.48;
            //vtec code
            var bits = new BitArray(vtecRaw);
            bool vtec = bits[0];
            //Speed kph
            double speed = vssRaw; //Do what ever conversion here
            //IAT C
              double iat = iatRaw;
              iat = iat / 51;
              iat = (0.1423* Math.Pow(iat, 6)) - (2.4938* Math.Pow(iat, 5))  + (17.837* Math.Pow(iat, 4)) - (68.698* Math.Pow(iat, 3)) + (154.69* Math.Pow(iat, 2)) - (232.75* iat) + 284.24;
              iat = ((iat - 32)*5)/9;
            //ECT C
              double ect = ectRaw;
              ect = ect / 51;
              ect = (0.1423 * Math.Pow(ect, 6)) - (2.4938 * Math.Pow(ect, 5)) + (17.837 * Math.Pow(ect, 4)) - (68.698 * Math.Pow(ect, 3)) + (154.69 * Math.Pow(ect, 2)) - (232.75 * ect) + 284.24;
              ect = ((ect - 32) * 5) / 9;
            // CRC CHECKING CODE HERE
            int checksum = byteData[0];
            int x = 0;
            while (x < 39)
                x++;
                checksum = checksum + byteData[x];
            byte calchecksum = (byte)(checksum & 0xff);
            if (calchecksum == byteData[40])
                //Check sum matched code here
                //MessageBox.Show("checksum match");
            else
                //Checksum failed code here.
            // Read error codes
            string errorstring = Reverse(ToBitsString(cel1)) + Reverse(ToBitsString(cel2))  + Reverse(ToBitsString(cel3))  + Reverse(ToBitsString(cel4)); ;
            char[] OBD1DTCL = errorstring.ToCharArray();
            int i = 0;
            while (i < 31)
                if (OBD1DTCL[i].ToString() == "1")
                    //Message box for each code (Code number = i + 1.
                  MessageBox.Show("error code " + (int.Parse(i.ToString())+1).ToString());
                i++;
        //Converts a byte to a 8 bit
        public static string ToBitsString(byte value)
            return Convert.ToString(value, 2).PadLeft(8, '0');
        //Inverts the bit string to make storing error codes as a 0-32 bit array easier.
        public string Reverse(string text)
            if (text == null) return null;
            char[] array = text.ToCharArray();
            Array.Reverse(array);
            return new String(array);
Author:  Majinsoftware [ Mon Feb 04, 2019 6:24 pm ]
Post subject:  Re: [DataLogging] QD3 Info C#
Thanks always wanted to work out the cel stuff
Author:  bmgjet [ Wed Feb 20, 2019 1:35 am ]
Post subject:  Re: [DataLogging] QD3 / ISR Info C#
ISR datalogging info (eCtune) (Honda Tuning Suite)
using System;
namespace HondaTuningSuite
    //Variable for every byte of datalogging coming out of ecu.
    class DLISR{
        public static char[] OBD1DTCL;
        public static int COLY;
        public static int COLV;
        public static int COLX;
        public static int GEARFuelC;
        public static int PWMTarget;
        public static float RPM;
        public static float IGN;
        public static float AFR;
        public static float VSS;
        public static float BATTERY;
        public static float MAP;
        public static float BOOST;
        public static float TPS;
        public static float IAT;
        public static float ECT;
        public static int MIL;
        public static int O2Heater;
        public static int VTS;
        public static int Baro;
        public static  int PostFuel;
        public static int ServiceConector;
        public static int IgnCut;
        public static int VTSM;
        public static int FuelCut1;
        public static int FuelCut2;
        public static int ATShift1;
        public static int ATShift2;
        public static double injFV;
        public static int injDuration;
        public static float injduty;
        public static float ignTable;
        public static int Park;
        public static int BKSW;
        public static int ACC;
        public static int VTPS;
        public static int Start;
        public static int SCC;
        public static int VTSFeedBack;
        public static int PSP;
        public static int FuelPump;
        public static int IABV;
        public static int ALTCTRL;
        public static int Purge;
        public static int AC;
        public static int ELD;
        public static double ECTFC;
        public static long O2Short;
        public static long O2Long;
        public static long IATFC;
        public static double VEFC;
        public static float IATIC;
        public static float ECTIC;
        public static float GEARIC;
        public static int InputFTL;
        public static int InputFTS;
        public static int InputEBC;
        public static int InputEBCH;
        public static int InputGPO1;
        public static int InputGPO2;
        public static int InputGPO3;
        public static int InputBST;
        public static int OutputFTL;
        public static int OutputAntilag;
        public static int OutputFTS;
        public static int OutputBoostCut;
        public static int OutputEBC;
        public static int Output2ndMap;
        public static int OutputFanCtrl;
        public static int OutputBST;
        public static double EBCBaseDuty;
        public static double EBCDuty;
        public static int OutputGPO1;
        public static int OutputGPO2;
        public static int OutputGPO3;
        public static int OutputBSTStage2;
        public static int OutputBSTStage3;
        public static int OutputBSTStage4;
        public static int OverHeatProtection;
        public static int LeanProtect;
        public static int EGR;
        public static int B6;
        public static int IACVDuty;
        public static bool _continue = true;
        //array to hold every value as a table.
        public static string[] DataloggedTable = new string[192000];
        public static string Reverse(string text)
    //Checks to see if a sensor bit is set.
    public static int GetSET(int ThisByte, int ThisPos)
        int[] bitArray = new int[8];
        for (int i=0; i< 8; ++i){
            bitArray[i] = ThisByte & 1;
            ThisByte >>= 1;
            return bitArray[ThisPos];
        //Gets fuel correction values
        public static double GetFC(long ThisByte, long ThisLong)
            double num = (double)ThisByte / (double)ThisLong;
            return Math.Round((num) * 100) / 100;
        public static long Long2Bytes(byte ThisByte1, byte ThisByte2)
            return ((long) ThisByte2 * 256) + (long) ThisByte1;
        //Gets ignition correction values
        public static float GetIC(byte ThisByte)
            if ((int)ThisByte == 128)
                return 0.0f;
            if ((int)ThisByte < 128)
                return (float)(128 - (int)ThisByte) * -0.25f;
            return (float)((int)ThisByte - 128) * 0.25f;
        //Gets duty cycle of boost solenoid
        public static double GetEBC(byte ThisByte)
            double num = (double)ThisByte / 2.0;
            if (num > 100.0)
                num = 100.0;
            return Math.Round((num * 10)) / 10;
        //Gets injector duration
        public static float GetDuration(int ThisInt)
        return ((float) ThisInt * 3.20000004768372f) / 1000.0f;
        //Process datalogging frame.
    public static void Process(int[] byteData)
                int ectRaw = byteData[0];             // Engine Coolant Temp Byte
                int iatRaw = byteData[1];             // Intake Air Temp Byte
                int o2Raw = byteData[2];              // Oxygen Sensor Byte
                Baro = byteData[3];                   //Baro sensor byte
                int mapRaw = byteData[4];            // Map Sensor Byte
                int tpsRaw = byteData[5];             // Throttle Position Sensor Byte
                int rpmLowRaw = byteData[6];           // Low Byte of RPM
                int rpmHighRaw = byteData[7];          // High Byte of RPM
                PostFuel = GetSET(byteData[8], 0);      //Post Start Fuel Enrichment
                ServiceConector = GetSET(byteData[8], 1);   //Service Connector status
                IgnCut = GetSET(byteData[8], 2); //Ignition cut status
                VTSM = GetSET(byteData[8], 3); //
                FuelCut1 = GetSET(byteData[8], 4);//
                FuelCut2 = GetSET(byteData[8], 5);//
                ATShift1 = GetSET(byteData[8], 6);//
                ATShift2 = GetSET(byteData[8], 7);
                COLY = byteData[9];                        //Map trace Y
                COLV = byteData[10];                       //Map trace vtec Y
                COLX = byteData[11];                        //Map trace X
                int cel1 = (byteData[12]);               // Cel Byte1
                int cel2 = (byteData[13]);               // Cel Byte2
                int cel3 = (byteData[14]);               // Cel Byte3
                int cel4 = (byteData[15]);               // Cel Byte4
                int vssRaw = byteData[16];             // Vehicle Speed Sensor Byte
                int injLowRaw = byteData[17];            // Injector low Byte
                int injHighRaw = byteData[18];           // Injector high Byte
                int ignRaw = byteData[19];              // Ignition Timing RawFat
                ignTable = (0.25f * byteData[20]) - 6f;
                Park = GetSET(byteData[21], 0);
                BKSW = GetSET(byteData[21], 1);
                ACC = GetSET(byteData[21], 2);
                VTPS = GetSET(byteData[21], 3);
                Start = GetSET(byteData[21], 4);
                SCC = GetSET(byteData[21], 5);
                VTSFeedBack = GetSET(byteData[21], 6);
                PSP = GetSET(byteData[21], 7);
                FuelPump = GetSET(byteData[22], 0);
                //int empty = GetSET(byteData[22], 1);
                IABV = GetSET(byteData[22], 2);
                //int empty2 = GetSET(byteData[22], 3);
                //int empty3 = GetSET(byteData[22], 4);
                ALTCTRL = GetSET(byteData[22], 5);
                Purge = GetSET(byteData[22], 6);
                AC = GetSET(byteData[22], 7);
                //int empty4 = GetSET(byteData[23], 0);
                //int empty5 = GetSET(byteData[23], 1);
                //int empty6 = GetSET(byteData[23], 2);
                //int empty7 = GetSET(byteData[23], 3);
                //int empty8 = GetSET(byteData[23], 4);
                MIL = GetSET(byteData[23], 5);
                O2Heater = GetSET(byteData[23], 6);
                VTS = GetSET(byteData[23], 7);
                ELD = byteData[24];
                int batteryRaw = byteData[25];         // Battery Byte
                ECTFC = GetFC(byteData[26], 128);
                O2Short = (long)GetFC(Long2Bytes((byte)byteData[27], (byte)byteData[28]), 32768);
                O2Long = (long)GetFC(Long2Bytes((byte)byteData[29], (byte)byteData[30]), 32768);
                IATFC = (long)GetFC(Long2Bytes((byte)byteData[31], (byte)byteData[32]), 32768);
                VEFC = GetFC(byteData[33], 128);
                IATIC = GetIC((byte)byteData[34]);
                ECTIC = GetIC((byte)byteData[35]);
                GEARIC = GetIC((byte)byteData[36]);
                GEARFuelC = byteData[37];
                InputFTL = GetSET(byteData[38], 0);
                InputFTS = GetSET(byteData[38], 1);
                InputEBC = GetSET(byteData[38], 2);
                InputEBCH = GetSET(byteData[38], 3);
                InputGPO1 = GetSET(byteData[38], 4);
                InputGPO2 = GetSET(byteData[38], 5);
                InputGPO3 = GetSET(byteData[38], 6);
                InputBST = GetSET(byteData[38], 7);
                OutputFTL = GetSET(byteData[39], 0);
                OutputAntilag = GetSET(byteData[39], 1);
                OutputFTS = GetSET(byteData[39], 2);
                OutputBoostCut = GetSET(byteData[39], 3);
                OutputEBC = GetSET(byteData[39], 4);
                Output2ndMap = GetSET(byteData[39], 5);
                OutputFanCtrl = GetSET(byteData[39], 6);
                OutputBST = GetSET(byteData[39], 7);
                EBCBaseDuty = GetEBC((byte)byteData[40]);
                EBCDuty = GetEBC((byte)byteData[41]);
                PWMTarget = byteData[42];
                OutputGPO1 = GetSET(byteData[43], 0);
                OutputGPO2 = GetSET(byteData[43], 1);
                OutputGPO3 = GetSET(byteData[43], 2);
                OutputBSTStage2 = GetSET(byteData[43], 3);
                OutputBSTStage3 = GetSET(byteData[43], 4);
                OutputBSTStage4 = GetSET(byteData[43], 5);
                OverHeatProtection = GetSET(byteData[43], 6);
                LeanProtect = GetSET(byteData[43], 7);
                EGR = byteData[44];
                B6 = byteData[45];
                IACVDuty = (int)(Long2Bytes((byte)byteData[49], (byte)byteData[50]) / 327.68);
            try
                RPM = 1875000 / ((rpmHighRaw * 256) + rpmLowRaw); //valid
            catch { RPM = 28; }
                injFV = (double)Long2Bytes((byte)injLowRaw, (byte)injHighRaw) / 4.0;
                injDuration = (int)Math.Round(((double)GetDuration((int)Long2Bytes((byte)injLowRaw, (byte)injHighRaw))) * 100) / 100;
                injduty = (float)((double)RPM * GetDuration((int)Long2Bytes((byte)injLowRaw, (byte)injHighRaw)) / 1200.0);
                //double knock = (0.00 * knockraw);
                //Ignition Advance
                IGN = (0.25f * ignRaw) - 6f;
                AFR = o2Raw / 51.0f;
                //TPS %
                TPS = (0.472637f * (float)tpsRaw) - 11.46119f;
                //Battery Voltage
                BATTERY = (26.0f * batteryRaw) / 270.0f;
                //Map Voltage
               // float mapvolt = mapRaw / 51;
                //Map Mbar
                float map = YourTune.B105.ConvertRange(0, 255, -70, 1790, int.Parse(mapRaw.ToString()));
                //float map = (1764 / 255) * (mapRaw) * 2 + 6;
                //Map inghg
                //double inHg = -10.87 * ((mapRaw) * 5 / 256) + 30.48;
                MAP = map;
            if (map > 1014)
                BOOST = float.Parse(Math.Round((map / 68.948) - 14.7, 2).ToString());
            else
                BOOST = 0;
            //Speed kph
            VSS = vssRaw; //Do what ever conversion here for ratio of wheels.
                //IAT C
                iat /= 51;
                iat = (0.1423 * Math.Pow(iat, 6)) - (2.4938 * Math.Pow(iat, 5)) + (17.837 * Math.Pow(iat, 4)) - (68.698 * Math.Pow(iat, 3)) + (154.69 * Math.Pow(iat, 2)) - (232.75 * iat) + 284.24;
                iat = ((iat - 32) * 5) / 9;
                IAT = (float)iat;
                //ECT C
                ect /= 51;
                ECT = (float)ect;
                //check error codes
                string errorstring = Reverse(ToBitsString((byte)cel1)) + Reverse(ToBitsString((byte)cel2)) +
                                         Reverse(ToBitsString((byte)cel3)) + Reverse(ToBitsString((byte)cel4));
                    if (double.Parse(errorstring) == 0)
                        else {
https://www.phpbb.com/
