It is currently Thu Nov 14, 2019 10:32 pm
PostPosted: Wed Jun 01, 2005 4:30 pm
Hi,
I wanna learn Visual C++, better said eMbedded Visual C++.
I've good knowledge of Pascal & Delphi Programming.
Has anyone a good suggestion of a site or good book where i can learn it in a crash-course?
TIA
Doc
 Post subject: tutorials listed
PostPosted: Sun Jun 05, 2005 2:10 pm
http://www.cprogramming.com/tutorial.html
http://www.glenmccl.com/tutor.htm
http://www.cplusplus.com/doc/tutorial/
Heres a few tutorials and i would recommend getting a book of commands if you already have programming knowledge it should be easy to pick up as most languages are similar. Im not great at creating objects in C++ but as far as basic C++ im good .. just practice making simple loop programs and see the differences in code between the languages. Hope this helps.
PostPosted: Wed Aug 10, 2005 1:32 am
I'd recommend taking a look at some of the O'Reilly & Associates books. I believe that Practical C++ Programming & C++ in a Nutshell might be useful just to give yourself a quick tutorial into C++. I do not have any experience with Delphi, but Pascal is similar in structure to C/C++, so it should not take a great deal to move to C/C++ and then add on to get to Visual/Embedded C++.
PostPosted: Wed Aug 10, 2005 5:07 am
Visual Studio is a great development environment, but the MS compiler is severly broken. A perfectly legal construct like this
for (int i=0;i<10;i++){
That statement yields some error 'like variable i used twice in the same scope'. (This bug is still present in the .NET compilers, I've reported this bug to MS over 8 years ago)
A couple of years ago there where lots of plugins that used another (gcc/intel) compiler instead of the msvc compiler. Another suggestion would be using the Eclipse CDT environment (http://www.eclipse.org/cdt/). But then again, I don't know what your motivations are for choosing MSVC. If you use it to learn C++, it's a bad choice, because the C++ dialect used by MSVC is severly bastardized.[/url]
PostPosted: Mon Oct 24, 2005 8:05 am
http://support.microsoft.com/kb/167748/en-us
PostPosted: Mon Oct 24, 2005 11:09 am
FastHatch wrote:
Funny :). I reported this bug back in (I think) 1997 and a fix was promised..
It's a shame such fixes are needed. And I wonder what 'fix' they have for C#, it has the same bug, and doesn't support #ifdef's..
Anyway, if you want to learn C++ (and not Micorsofts broken version), use GCC...
PostPosted: Mon Oct 24, 2005 11:50 am
i know i'll get flamed over this, but i recomend you dont.
you should lean to use GCC and pick whatever dev system you want.
all this stuff comes as standard with most linux install's together with the manuals.
once you can use GCC you can compile your code for windows, linux, osx and anything else.
better that than limiting yourself to windows.
visual is buggy anyway.
PostPosted: Mon Oct 24, 2005 4:30 pm
GCC is not a good compiler to start learning C++. The way how the vtable of virtual methods is implemented is a mess. Line concatenation doesn't work with CR+LF etc. etc. Linking objects created with gcc and g++ also often doesn't work. GCC throws too many confusing errors.
Packing alignment also behaves odd, #pragma pack ( 1 ) has to be used in conjunction with __attribute__ ((packed)), otherwise GCC uses default alignment.
We're using GCC for our multimillion LOC (automotive / multimedia) projects and gcc has so many odds you have to be aware of.
Microsoft promised that the new 2005 Studio fully complies the C++ standard.
Btw. the Borland compiler has the same for-init-statement bug as MSVC.
PostPosted: Mon Oct 24, 2005 5:36 pm
Ahah! More proof that M$ steals all of the code they use! :lol:
PostPosted: Wed Oct 26, 2005 10:09 am
:lol:
microsoft making a promise? that's about as trustable as bush/blair saying war is a final option or macdonalds making a healthy meal!
call me untrusting, but i'v seen gates speaking shit about upcoming products since the 80's and he still hasnt followed through.
my fav' quotes: "windows is dead, os2 is the future!" & "nobody will use blue-ray because the DRM is so anti-consumer" :D
PostPosted: Sun Nov 27, 2005 3:04 pm
As said this is perfectly valid with VS2005 now. Just tested it with my VS2005 Professional installation.
The downside is, many projects rely on this bug and now you have to fix it everywhere. And if you put an 'int' in front of all declarations it can't be compiled with any previous version. I suggest to put the declaration somewhere before the first for-loop.
Andre
